vassen Posted May 21, 2020 Share Posted May 21, 2020 Hello everyone, Do you guys uses Vectorworks Dormers? If you want to personalise the vectorworks dormers can we do it? or else how do you guys create your dormers from scratch? Might be in future release we might be able to select the place we want to place the dormers with our cursor. Thanks for some ideas and help Quote Link to comment
Vectorworks, Inc Employee Wes Gardner Posted May 22, 2020 Vectorworks, Inc Employee Share Posted May 22, 2020 @vassen, I use the automatic dormer creation sequence to build a conceptual dormer getting it close in size and location on the roof. I then ungroup the dormer resulting in roof faces and walls. From there you can use wall styles, etc. on the dormer. Wes 3 Quote Link to comment
vassen Posted May 22, 2020 Author Share Posted May 22, 2020 @Wes Gardner Thanks i did not think of ungrouping it. will give it a try. Quote Link to comment
DBrown Posted May 30, 2020 Share Posted May 30, 2020 Yes, the roof object is very limited in Vectorworks, but if you ungroup it you can have more freedom using it 1 Quote Link to comment
Mi&D Posted June 22, 2021 Share Posted June 22, 2021 On 5/22/2020 at 3:34 PM, Wes Gardner said: @vassen, I use the automatic dormer creation sequence to build a conceptual dormer getting it close in size and location on the roof. I then ungroup the dormer resulting in roof faces and walls. From there you can use wall styles, etc. on the dormer. Wes Hi Wes, I'm Michael from Switzerland. I've tried your suggested method to create a trapezoidal dormer. The result is promising. I have a conflict though with the lateral roof parts of the dormer... They aren't walls nor are they roof faces. They come as 3d-polygons. I can't seem to get these polygons under control. They should look the same way as the roof in section. Is there a way to transform this inclined 3d-polygons into roof-faces or any other element that looks ok in section? 1 Quote Link to comment
Vectorworks, Inc Employee Wes Gardner Posted June 24, 2021 Vectorworks, Inc Employee Share Posted June 24, 2021 @Mi&D, Hi there...yes, if they are inclined that will happen - Vectorworks cannot produce canted walls. Your best bet is to either model them from extrudes or try a roof face. If you can't get the 3D polys to behave, you may be able to edit the 3D poly and get to the 2D poly that made it (or trace a 2D poly)? If so, I would then try either roof faces of extrudes. Wes Quote Link to comment
Mi&D Posted June 24, 2021 Share Posted June 24, 2021 Hi Wes Thanks for reply. I've tried it with roof faces. I got it done, but the result isn't yet satisfying. Have a look at these 2 screenshots. In section we have an extrude on the left and a roof face on the right. Somehow roof faces do not behave the way I'd like them to: Joining single roof layers - like insulation in this case - isn't possible. Quote Link to comment
Mi&D Posted June 25, 2021 Share Posted June 25, 2021 17 hours ago, Wes Gardner said: Vectorworks cannot produce canted walls Hi Wes. This statement makes me think. Why is it not possible to tilt a wall in an advanced CAD software like Vectorworks? Quote Link to comment
Tom W. Posted June 25, 2021 Share Posted June 25, 2021 4 minutes ago, Mi&D said: Why is it not possible to tilt a wall in an advanced CAD software like Vectorworks? Very good question! See: Quote Link to comment
Mi&D Posted June 25, 2021 Share Posted June 25, 2021 (edited) @Tom W. Thanks for the hint. I knew there must be more than this...I'll have a look at this thread anytime soon. Edited June 25, 2021 by Mi&D Quote Link to comment
Mi&D Posted June 25, 2021 Share Posted June 25, 2021 @Tom W. Hi again. It's outstanding what an effort some of our colleagues make to get there. I have one issue to resolve: How to change a roof face into a solid object or into a subdivision? Actually, starting from a dormer, I'd like to get to a solid or subdivision body to reshape it. The roof face seems to be very stubborn. I can't find a way to ungroup or explode it. Quote Link to comment
Tom W. Posted June 25, 2021 Share Posted June 25, 2021 Hi @Mi&D I'm not sure I can help you. I have not used Roof Faces much: I've found them quite frustrating/underwhelming the little I've done with them. If I was attempting to build something like that my first port of call would probably be to try making it using Slab objects as you have a lot more control over the individual components, the size/shape of the edges etc.+if it's important to have a BIM object that accurately reflects the real world construction. But then, as per the other thread, you are restricted to a 45 degree incline on the cheeks... Have a look at this post: @drelARCH is successfully using Slabs to create something similar to what you are trying to do Quote Link to comment
Mi&D Posted June 25, 2021 Share Posted June 25, 2021 Hi @Tom W. Thank you. This is fascinating. I'll have to try this alternative methods, even-though in my specific case the lateral part of the trapezoidal dormer is at 63°. Anyways I want to learn the use of inclined slabs. 1 Quote Link to comment
Mi&D Posted June 28, 2021 Share Posted June 28, 2021 @Tom W. I did some research meanwhile concerning roof faces offset: - 2 faces with equal angle : offset is ok - 2 faces with different angle: offset with troubles - 1 face is 0° (flat) : offset doesn't work... see screenshots 1,2,3 Am I doing something wrong? Or is it a bug? Quote Link to comment
Tom W. Posted June 28, 2021 Share Posted June 28, 2021 See this thread: Sounds like you've identified the same problems. This is what I was referring to when I said I found them underwhelming... Quote Link to comment
Mi&D Posted June 28, 2021 Share Posted June 28, 2021 Thanks @Tom W. You guys rock! In our European Forum we don't get that far in analyzing tools and looking for solutions. Great effort! I'll have to study this. 1 Quote Link to comment
Mi&D Posted June 30, 2021 Share Posted June 30, 2021 (edited) @Tom W. At least I got closer to solve it. In my example of trapezoidal Dormer I succeeded in joining 2x2 roof faces. (It hasn't been possible to join a pair 2-layered roof faces). Still, I have some issues at the offset. There is one edge that shouldn't be there. And the at the inner intersection lines do not meet in the same point... Is this the best we can get? PS. In the thread I've found your statement: "to join two Roof Faces using Dual Object Connect Mode + Mitre Roof Face Joins Mode". I am using a Swiss version of VW. Could you please show me the icons of these 2 Modes. I might need to check... On the other hand, you're mentioning, that the horizontal face should be set at 0.1° (trick). Unfortunately, in my case I can't rotate the 8° (y-axis) face 0.1° in the other direction (x-axis)... Do you know a way how to incline the roof face in both directions (0.1° and 8°)? This would solve the problem I guess. Edited June 30, 2021 by Mi&D Quote Link to comment
