Refresh Instruments by Layer Project Sharing
KRMLighting
I cannot refresh instruments when project sharing because other people have checked layers with spotlight objects which means I have to restart the file every time the graphics start to get screwy.  It would be great to refresh instruments by layer or on all checked out layers. Is there a workaround I am missing?
1 answer to this question
Refresh instruments also works based on a selection.
If you have your layer options set to active only, you can select all then run refresh instruments it will only refresh the selected lighting devices.
