C. Andrew Dunning
Boolean Operations w. Data Visualization
Is there any way to use Boolean operations in the Data Visualization system?  I'm wanting something like this (copied from a Report):
=((('RigPoint'.'Type'='1-Ton') & (VALUE('RigPoint'.'LoadWeightLB')>2000)) | (('RigPoint'.'Type'='1/2-Ton') & (VALUE('RigPoint'.'LoadWeightLB')>1000))).
Thanks for any help...
please display the RigPoints with the requested attributes that meet the following criteria:
The ".Type" parameter equals "1-Ton" AND the "LoadWeightLB" parameter greater than 2000
OR
The ".Type" parameter equals "1/2-Ton" AND the "LoadWeightLB" parameter greater than 1000
It looks like he wants data display to flag overloaded rig points.
RigPoint is a production rigging PIO.  I want to mark each instance w. a load that is over-spec.  So...essentially...I want to mark instances with a type of 1-Ton and a load weight of > 2000 lb or a type of 1/2-Ton and a load weight of > 1000 lb etc.
That help?
So, as I read this you want different types of hoists to be collected as long as they are over 1000 lbs. As opposed to selecting just a specific type of hoist?
I don't have the answer, but this seems a reasonable VE If not possible.
In VW2020 you should be able to define the Criteria section at the top of the Edit Data Visualization dialog box to contain the criteria you have.
Edit the Display Criteria color in the bottom box and make sure you have the Apply Attributes box checked in the Edit Attributes Value dialog box.
I do have the Criteria box but it doesn't (that I can tell) allow me to do a series of ANDs and ORs like I'm wanting.  I do see a space in the dialog that shows the "long-hand" result of the dialog but I can't edit that the way I could w. Reports.  I was really hoping someone had figured out a way to do that...
Set up a different visualization for each OR condition and then use the Select Multiple Vizualizations to turn them both on at the same time.
I'll jump in on the requests since this started with a question I have for Andy.  I was not having much luck making this work and would be fine even if I had to have a DV for each type of hoist.  ....and Pat beat me to it.
