Giovanni Posted May 18, 2020 Share Posted May 18, 2020 I've a problem with the components of a wall. In Figure1 you can see a corner joint of a wall, and it's good when i'm in plain/top view. You can see all the 3 components of the first wall (numbered 1, 2 and 3) and all the 3 components of the second wall (numbered 4, 5 and 6). In Figure2 you can see the 3D point of view of the same corner. Figure3 is a detailed view with the selected walls showing components. Component 3 isn't visible and the thickness of the wall is lower that the ones yu can seen i plain view. Is this a known issue. How can I fix it? Thank you Quote Link to comment
Guest Wes Gardner Posted May 19, 2020 Share Posted May 19, 2020 @Giovanni, best thing to do is post a file with the offending wall(s) so we can have a look at your set-up. Wes Quote Link to comment
Pat Stanford Posted May 19, 2020 Share Posted May 19, 2020 Check the settings in the Render tab of the OIP for the walls. It looks like you might have the rendering set to By Object rather than By Component. Quote Link to comment
Giovanni Posted May 20, 2020 Author Share Posted May 20, 2020 This is the file we are working on. It's seems that the missing component is set to be set at height of 0 (so not visible on the top). 3 people have worked on this file so maybe we have some error in defining components height and I'm working to check those inconsistencies. Here attached you can find a new picture where you can see that the missing component in visible before the connection with the center wall. Stato Progetto V07exp.vwx Quote Link to comment
Giovanni Posted May 20, 2020 Author Share Posted May 20, 2020 @Pat Stanford The rendering is set to Object but the component is still missing if we change it to "by component". Quote Link to comment
Guest Wes Gardner Posted May 20, 2020 Share Posted May 20, 2020 Looking at the model, that particular wall is Wall Style TPS30 EX - it is set with a Top Bounding of Piano [Story Above]. In this model there is no Story Above for the wall style's level to "see" or to bind to. It appears that you've used "Fit Walls to Objects Above"? My Italian just isn't good enough to go through how the walls are set to interface with the roof system. This may be the reason the interior component isn't working properly. My advice is to NOT use Stories and just set the whole model up using Layer bound walls styles. Wes Quote Link to comment
A McDonell Posted May 21, 2020 Share Posted May 21, 2020 anyone else with this... (clip cube is on) (clip cube is off) Quote Link to comment
Giovanni Posted June 5, 2020 Author Share Posted June 5, 2020 @Wes Gardner We think the problem was due to the height of the components. All invisible components where set to a height of 0 so they doesn't appear at the top of the wall (but they're visible in the top/plan view). We have follow your suggestion and it's seem to work. Quote Link to comment
