MullinRJ Posted May 15, 2020 Share Posted May 15, 2020 What is the replacement for VS command SetWallHeights()? The DevWIKI documentation says "See architectural category for replacement". So I went to Objects - Architectural and of the 125 commands listed absolutely nothing looked even remotely similar. In the Objects - Wall section, WallPeak() looks like it could be made to function to set a "peak" at the end of the wall, but it is a MiniCAD 4 command and it doesn't seem like it would be the replacement for a command deprecated in VW 2012. I assume I'm missing the obvious, so any help would be appreciated. Thank you, Raymond Quote Link to comment
Pat Stanford Posted May 15, 2020 Share Posted May 15, 2020 I don't have time to play right now, but if you have a Wall that is not Bounded to a Story Layer (Level?) and that has no Wall Peaks, I think you can use SetObjectVariableReal 616 to set the Wall Average Height. Quote Link to comment
MullinRJ Posted May 15, 2020 Author Share Posted May 15, 2020 Thanks, Pat. I tried setting that ObjVar, but nothing happened. When I looked it up I saw it is READ ONLY. It seems strange that SetWallHeights() very easily set the wall's height at its beginning and its end. Why would a command like that be removed without another to take it's place? And if one did take it's place, it would be nice to see a note along with the deprecation notice showing which command to use in its stead. This short script achieves the look of the wall that SetWallHeights() produced, but the Wall Height in the OIP remains unchanged, which doesn't feel right. Is this the way to go? PROCEDURE xxx; procedure SetWallHeightsN(H :Handle; StartWallHt, EndWallHt :Real); { Set the wall heights at the beginning and end of a straight wall. Prior peaks are removed. } Var P1, P2 :Vector; Begin ClearWallPeaks(H); GetSegPt1(H, P1.x, P1.y); GetSegPt2(H, P2.x, P2.y); AddWallPeak(H, 0, StartWallHt); AddWallPeak(H, Norm(P2-P1), EndWallHt); End; { SetWallEndHeights } BEGIN SetWallHeightsN(FSActLayer, 8', 9'); SysBeep; END; Run(xxx); Comments welcome. Thanks, Raymond Quote Link to comment
Pat Stanford Posted May 15, 2020 Share Posted May 15, 2020 Check the scripts by Robert Anderson and me in this thread. 1 Quote Link to comment
Julian Carr Posted May 15, 2020 Share Posted May 15, 2020 SetWallCornerHeights() might work. 1 Quote Link to comment
MullinRJ Posted May 16, 2020 Author Share Posted May 16, 2020 Pat, Julian, Thank you both. Julian, that is indeed the command I was looking for, but it does not work out of the box. On my first attempt using this function my initial excitement was quickly dashed when — nothing happened. Then I reread the thread Pat posted. At the end of his example script he included a ResetObject() command. Together these commands make the wall display as expected, but there was still something missing. Even after the wall height is set at either end, the HEIGHT parameter in the OIP does not update to reflect the change. I don't know if this is normal or not, but it didn't feel right to me, so I dug a little deeper. I drew two walls of different heights in a blank document and exported the file as VectorScript. The wall heights are set with ObjVars 604 to 607, which are marked as "Not for public use" but they work just fine if you don't tell anybody what you are doing, and you convert everything to mm first. These commands are followed by SetObjectStoryBound(), which sets the OIP fields HEIGHT and TOP OFFSET. Though I am still not fluent in Wall terminology, I feel much better with the output of these combined commands. Here's a small function I put together. I hope it helps someone get past these small hurdles. It should be pretty easy to modify this script to also set the bottom elevations of the wall, if needed. Comments and criticisms are definitely welcome. function SetWallHeights1(H :Handle; StartHt, EndHt :Real) :Boolean; { Set the wall height at the beginning and end of a straight wall and update the OIP. } { Return TRUE if the function works, FALSE otherwise. } Var B :Boolean; Begin B := SetWallCornerHeights(H, StartHt, 0, EndHt, 0); if B then begin SetObjectStoryBound(H, 0, 0, 0, '', 0); { affects OIP Top Offset } SetObjectStoryBound(H, 1, 0, 0, '', max(StartHt, EndHt)); { updates OIP Height } ResetObject(H); end; { if } SetWallHeights1 := B; End; { SetWallHeights1 } A little be of Pat, and a little bit of Julian, makes the world go round. Thanks, guys. Raymond Quote Link to comment
