plug-in object
Hi,
I added my own custom record to a projector in the projector models.vwx file.
When i use the "Video Screen tool" and i select the projector where i attached the record to, it imports the record format in my active drawing.
Now i made some "auto generate worksheets" in vectorscript and i want to seach for the record but it only works if i check the "plug-in object" checkbox in the header search criteria.
Does somene knows how to enable the "plug-in object" option in the script.
my script:
dynCharArray:DYNARRAY [] OF CHAR;
var tH :handle;
dynCharArray := '=DATABASE((INSYMBOL & (R IN [''[Faber]Projection'']) & (''[Faber]Projection''.''Amount''>=1)))';
SetWSCellFormulaN(tH,5,0,5,0,dynCharArray);
        SetWSCellFormula(tH,5,1,5,1,'=(''[Faber]Projection''.Amount)');
        SetWSCellFormula(tH,5,2,5,2,'=(''[Faber]Projection''.Brand)');
        SetWSCellFormula(tH,5,3,5,3,'=(''[Faber]Projection''.Type)');
