halfcoupler Posted May 15, 2020 Share Posted May 15, 2020 I wonder if this is a bug or if thats me wo does not understand how record formats are attached: - drag a symbol with record format "A" attached into a drwaing - replace this symbol via the replace button in the OIP with some other symbol which has different record format "B" attached. Result : the symbol is replaced, but the record format "A" keeps sticked to the instances that are already in the drawing. I expect the record format to be replaced too.... If it's correct and intended that record formats are not replaced in this way, how can I teach my drawing to replace the record format for all instaces ? Quote Link to comment
halfcoupler Posted May 15, 2020 Author Share Posted May 15, 2020 (edited) 49 minutes ago, halfcouple said: how can I teach my drawing to replace the record format for all instaces ? ok, solved so far, as explaind in the help file: - select the desired instances, select the desired record format, right-click => attach. But this seems to be a one way road, field values of instances can not be overwitten by replacing the symbol definiton... Edited May 15, 2020 by halfcouple Quote Link to comment
Pat Stanford Posted May 15, 2020 Share Posted May 15, 2020 You are correct. The Default values are just that Default. Once a record has been attached to an instance there is no longer any link to the values on the Symbol Definition or to the Record Defaults. You can use a worksheet to make it easier to do bulk edits of objects with records that are already placed in the drawing. Quote Link to comment
halfcoupler Posted May 16, 2020 Author Share Posted May 16, 2020 (edited) Hi Pat, right, from a programmer's view this seems all logical. From a users view this seems all unlogical, unless the user is a programmer. 😀 Since I'm only a "super-mini-mini-programmer", I have found my workaround for replacing existing record format values in a drawing: What is NOT working: - dragging a Symbol definition with new record format and/or new values to the drawing: This will only affect the symbol definition and the new instance, but not the existing instances. - using the attaching/detatching tools from the Menue->Tools->Records: This tool affects only the symbol definitons in the file, and leaves the existing instances untouched. - Replacing symbol instances with a symbol definition that has other record format(s) attached than the record format of the instances: This will result in adding the new record format to the instance(s) additional to the old one, which stays untouched. ( I am not shure, but I think somewhere there is a rule setting for that behavior about adding/merging record formats ?) What works: - replacing symbol instances that have exact the same record format as the new symbol definition, only with other values: The old values will be overwritten. Hope this clarifies a bit for others who might stumble over this thread. Edited May 16, 2020 by halfcouple Quote Link to comment
Pat Stanford Posted May 17, 2020 Share Posted May 17, 2020 It is actually about the only way a "simple" database can work. It would be far worse to not be able to have records that were individual for a specific instance of an object. Or even worse have things that you customized for a specific instance changed back to the default when someone edited the symbol or the record. There have been a number of requests for a field type that would be linked back to either the symbol or record definition and would update when the "master" is updated. I see this as kind of like Styles and the ability to make some fields By Style and some By Instance. I have my fingers crossed (but I am not holding my breath) that we may see an update in the next couple of versions of VW. Quote Link to comment
