MartinBlomberg Posted May 15, 2020 Share Posted May 15, 2020 Hi, I'm doing a drawing with my plan rotated -22 degrees to make GIS image horizantal to my design. When I push the Num 0, more or less every second time VW gives me the -22 degree look, and every other time the 0 degree look. How do I make my -22 degree look stick to my design until I say otherwise? Thanks! Quote Link to comment
Pat Stanford Posted May 15, 2020 Share Posted May 15, 2020 I think you are going to have to change your habits. ;-) As far as I know, if you are working in Rotated view and are in a view other than Top/Plan, hitting the Zero key switches you back to the Rotated Top/Plan view. If you are already in Rotated Top/Plan, the Zero key switches you back to Unrotated Top/Plan. So you either need to train yourself to not hit Zero when you are in Rotated Top/Plan, or you need to learn the keyboard shortcut for Previous View so you can get back to the Rotated view easily. In the default workspace that shortcut is Command, Shift - Comma (,). On a US keyboard you can think of this as Command - < (less than) Quote Link to comment
MartinBlomberg Posted May 15, 2020 Author Share Posted May 15, 2020 (edited) 6 minutes ago, Pat Stanford said: I think you are going to have to change your habits. 😉 As far as I know, if you are working in Rotated view and are in a view other than Top/Plan, hitting the Zero key switches you back to the Rotated Top/Plan view. If you are already in Rotated Top/Plan, the Zero key switches you back to Unrotated Top/Plan. So you either need to train yourself to not hit Zero when you are in Rotated Top/Plan, or you need to learn the keyboard shortcut for Previous View so you can get back to the Rotated view easily. In the default workspace that shortcut is Command, Shift - Comma (,). On a US keyboard you can think of this as Command - < (less than) Aha, alright. The funny thing is that it sometimes, even though I'm in a different view, gets me back to the original view. But I'll check into the new habits 😃 Warm regards and many thanks!! Edited May 15, 2020 by MartinBlomberg Quote Link to comment
