How to get rid of decimal places with #Landscape Area#.#area# on a data tag
Hi all. I am still having trouble with decimal places on the data tag, especially with #Landscape Area#.#area# and plant quantity.
The problem: Too many decimal places on a data tag. I want to get rid of all decimal places. Pretty obvious this is not governed by the overall units setting.
686817846_ScreenShot2020-05-15at18_08_51.thumb.jpg.be233c4c934a1039f79b8e4de6e1b493.jpg
I followed the solution in another thread (See below) to remove decimal places for plant quantity. But similar approach didn't work for #Landscape Area#.#area#. No matter which Number Format I choose, the decimal places remain on the data tag.
Any idea?
1914137525_ScreenShot2020-05-15at18_09_11.thumb.jpg.e962ed4de75f183d95ffe5397b8a3f81.jpg
234390345_ScreenShot2020-05-15at18_10_11.thumb.jpg.dd47ab2fc743421742f61cbe479880e3.jpg
I believe you have to add the formatting into the data tag itself.
Either Edit the Tag Style or if you only want to change it for a single tag convert it to Unstyled and then edit the tag.
Bottom of the OIP click the Edit Tag Layout button.
Select the text block that represents the field you want to change the formatting for.
Botton of the OIP click the Define Tag Field button
In the dialog box that opens
    delete the "formula" that is currently in the Current Tag Definition Field
    set the units to something other than Document Preferences
    set the Precision to the number of decimal places you want.
CLICK THE ADD TO DEFINITION BUTTON (Yes, I am yelling because about 90% of the time I forget this step and have to do the whole thing again). ;-)
Click OK
Click Exit Tag Layout Edit
Once you figure out how it works, you can actually just type for format you need into the Current Tag Definition field.
HTH
  • 7 months later...
I’m trying to do the same thing with Area and Function in the Space Tool Label (not a data tag):
1881241699_ScreenShot2020-12-21at4_36_27PM.thumb.png.73b77bcb3bc1c339479c28a00db93252.png
For Area, I would like to add a separator.
For the function (Mac Occupancy), I would like to remove decimals.
However, I can’t seem to edit the Record Format Connection. Text, Number, and Integer seem hardwired in there…
OK, I’m sure it’s only a matter of time before this bites me in the arse but here’s a workaround:
1. Change document units for Area > Unit Mark to a [space] (highlighted in light blue below):
1918665360_ScreenShot2020-12-22at6_27_03PM.thumb.png.c02bb189b17b72446c6417c437c25ee3.png
2. Add “sq ft” (or ft² or whatever you want) to the end of the Data Tag formula for:
  • Gross Area
  • Net Area
  • Load Factor
429945763_ScreenShot2020-12-22at6_25_59PM.thumb.png.64f9b883fc6f5a79a1181c30be696736.png
That solves everything except the thousands separator which I believe is a much deeper rooted issue:
2048435214_ScreenShot2020-12-22at6_27_23PM.thumb.png.6a965b1171b03ecfa31508f4818f70e2.png
