Laura Stone Posted May 14, 2020 Share Posted May 14, 2020 Anyone have any idea why it is making such a mess of the bund on the right? Laura Stone PondCutFill.vwx Quote Link to comment
Vectorworks, Inc Employee bgoff Posted May 14, 2020 Vectorworks, Inc Employee Share Posted May 14, 2020 First, use pads instead of contour lines and ensure they are closed. Second there is no need to model every contour elevation only major transitions in the model. So the .22M to .82 M could be eliminated. This will make for less calculating vertices speeding up the DTM recalculation time. Quote Link to comment
Rossford Posted May 14, 2020 Share Posted May 14, 2020 (edited) Yes, that does take a long time to do anything and freezes up. We do a lot of similar grading. It appears you simplified polys which is good. You can try to simplify more, especially since the smoothness of the site model shouldn't be apparent or important below water. Someone once told me that contour lines with tens of vertices are better than hundreds, which should be the max. If any contour counts in the thousands of vertices it will take forever to calculate, so keep simplifying until you get the count as low as possible and still achieve the look you want. Looks like most of yours have in the tens to low hundreds, so I think Bryan is right - try only the top and bottom contours, which should probably give you what you want. Edited May 14, 2020 by Rossford Quote Link to comment
Laura Stone Posted May 14, 2020 Author Share Posted May 14, 2020 Thanks, I have tried that on the RHS bund, but still not getting the right result - see attached. The pads are a workaround but feel the contours should work in a future update. Laura PondCutFill.vwx Quote Link to comment
Laura Stone Posted May 15, 2020 Author Share Posted May 15, 2020 Even stranger, if I mirror the bund to the north VW calculates it perfectly Laura PondCutFill.vwx Quote Link to comment
