HMichael Posted May 13, 2020 Share Posted May 13, 2020 Hey guys, I've made a 3D model which I tried rendering using renderworks final. I noticed that when I zoom in and out of the visualisation, an outline shortly appears around the buildings, which I actually prefer esthetically. Is there a way I can manually add this outline in the final outcome? Thanks in advance Michael Quote Link to comment
Hans-Olav Posted May 13, 2020 Share Posted May 13, 2020 Hi If you create a sheetlayer and make a viewport with your view, you will be able to assign a renderworks render to the background view and a line render to the foreground view . I would have tried custom renderworks instead of final, usually the highest settings is unnecessary and just adds rendering time. https://app-help.vectorworks.net/2020/eng/index.htm#t=VW2020_Guide%2FViewports1%2FViewport_properties.htm&rhsearch=foreground render&rhhlterm=foreground render&rhsyns= 1 Quote Link to comment
