Julian Carr
Sheet Layer Number and Name Export
Anyone have a script handy that will export a list containing sheet layer names and numbers?
TIA.
No, but this thread has a script that will make a worksheet of design layers.
Change the GetObjectVariableInt(H2,154)= 1. (I think Sheet Layers are 2) and you should get a worksheet of the sheet layers. Adding the Sheet Numbers should be relatively easy. I would probably change LayerSort to a Struct with two strings. Store the name and number in the struct and then add a second SetWSCellFormula line.
HTH.
Posted (edited)
Hi Julian,
   Do you mean something like this?
PROCEDURE xxx;
CONST
	CR = chr(13);
VAR
	H :Handle;
BEGIN
	H := FLayer;
	while (H <> nil) do begin
		if (GetObjectVariableInt(H, 154) = 2) then
			AlrtDialog(concat('Sheet # = ', GetLName(H), CR,
					'Sheet # [Title] = ', GetObjectVariableString(H, 162)));
		H := NextLayer(H);
	end;		{ while }
END;
Run(xxx);
By Export, do you mean write to a file? If not, how to format it?
Raymond
Edited by MullinRJ
