fuberator Posted May 10, 2020 Share Posted May 10, 2020 Hi I imported step files and they were drawn very fast in openGL. I had to convert them to get rid of some geometry so i chose nurbs. Now they are very slow to update. I have to watch as face after face is drawn. How can I convert them back to something less clunky? thank you Quote Link to comment
markdd Posted May 10, 2020 Share Posted May 10, 2020 After you made the adjustments did you run the add solids command and then convert to generic solid? Maybe that’s the answer? Quote Link to comment
fuberator Posted May 11, 2020 Author Share Posted May 11, 2020 hi I just converted it to nurbs, edited it slightly and then made a symbol Quote Link to comment
markdd Posted May 11, 2020 Share Posted May 11, 2020 On a copy of the symbol, try running the add solids command to the geometry and converting to Generic solid and then compare which runs faster. Quote Link to comment
fuberator Posted May 11, 2020 Author Share Posted May 11, 2020 that worked wonders, thank you Quote Link to comment
