jpccrodrigues
Extrude Along Path Problem
Hi guys,
Designing a bench for a project, used the Extrude Along Path tool.
In a empty file, result looks ok.
When I copy that or try to do the operation on my working file it gets all funky...
Any clue about the problem? I usually don't use 3d model tools, so I'm a little bit lost on this chapter.
Thanks!!!
João Rodrigues
Make sure your OpenGL settings are set to High in the new document.
you might run onto more problems as you work, I have ru into unresolved issues with rendering and viewport qualities which I enumerated in a post whole ago, no worries now, but if you run into the same problems let me know, the problems are better visible when on a big screen:
