Extrude Along Path Problem
Hi guys,
Designing a bench for a project, used the Extrude Along Path tool.
In a empty file, result looks ok.
When I copy that or try to do the operation on my working file it gets all funky...
Any clue about the problem? I usually don't use 3d model tools, so I'm a little bit lost on this chapter.
Thanks!!!
João Rodrigues
you might run onto more problems as you work, I have ru into unresolved issues with rendering and viewport qualities which I enumerated in a post whole ago, no worries now, but if you run into the same problems let me know, the problems are better visible when on a big screen:
