Lost the Attributes Palatte on my Designer Workspace
AWaters
I'm working on a Surface tablet with an extended monitor. I moved Vectorworks between the tablet screen and the other monitor and the Attributes palette disappeared. If I switch workspaces it is still around but I have no idea where it is when I'm in the Designer workspace. And yes it is checked in the Window>Palettes menu.
2 answers to this question
Try this:  with VW open set the resolution on your monitor to something much lower than what it normally does. This should cause all of the windows to shift to be in the visible area of the screen. Set the resolution back to what you normally use. All the windows/palettes should stay where they are. Rearrange your palettes/windows back to how you like them.
