Selim Posted May 5, 2020 Share Posted May 5, 2020 How can I add a railing for a curved ramp. The 3D railing tool only works in straight lines, and the railings that snap to a curve are all the same height level Quote Link to comment
Diego - Resuelvector Posted May 6, 2020 Share Posted May 6, 2020 The Railing tool have a mode where you can put railings going up in a slope Quote Link to comment
domer1322 Posted May 11, 2020 Share Posted May 11, 2020 you could try this work-around: make the walking surface of your ramp as a slab or generic solid. Then use the extract tool to extract the edge of the slab as a NURBs curve. Use the NURBS curve as the path for an extrude along path with the handrail profile. Also use the NURBS curve to duplicate many balusters along a path. This will work if the railing and guards are not too complicated, but even small ironwork patterns can be duplicated along the NURBS path if you wish. I was doing this for a project when I read your inquiry and it is working for me. I hope this helps. Quote Link to comment
