Jeff Prince Posted May 4, 2020 Share Posted May 4, 2020 I threw together a model of an existing pool & hardscape surfaces for the purposes of showing a planting design in 3D. I made the gravel planting beds, pool deck, and lawn area using the Hardscape Tool, which is great in both Top/Plan and 3D views. However, I built the curved feature walls and stone caps as extrusions. These look fine in 3D, but the Top/Plan view looks like a hidden line rendering with the all the edges showing but no fill. I encountered this issue too with the pool water that I had extruded and resolved by changing the water to a hardscape object. I really don't want to rebuild the feature walls and caps as Wall Object if I can avoid it. Is it possible to get the Top/Plan view of these specific features to show an outline and a fill like my other hardscape elements? thanks for any help, Jeff Quote Link to comment
markdd Posted May 4, 2020 Share Posted May 4, 2020 You could select all the feature objects you need to show in Top/plan and convert them to one symbol. Then add the Top/plan geometry to the Top portion. Quote Link to comment
Jeff Prince Posted May 4, 2020 Author Share Posted May 4, 2020 13 minutes ago, Pat Stanford said: Autohybrid? Great suggestion, this is a new command for me and seems to do the trick. Are there any issues with converting something to an Autohybrid in regards to editing geometry? thanks, Jeff Quote Link to comment
Jeff Prince Posted May 4, 2020 Author Share Posted May 4, 2020 while we are at it on this example... Is is possible to use VW Wall Styles to create walls that have decorative caps like the attached image? I've just been doing it by extruding 2D geometry. It sure would be nice if it could be done using a wall object instead. Quote Link to comment
