grant_PD Posted May 3, 2020 Share Posted May 3, 2020 Is there a way to rotate text to various planes, so that it can be viewed as a 3d object? Quote Link to comment
Pat Stanford Posted May 3, 2020 Share Posted May 3, 2020 It is harder to move already created text, but if you are creating the text, you can create a working plane and then use the Text tool to add text to the plane. Once you have text in the drawing, if it is not Screen Plane or Layer Plane it will probably say it is 3D plane. In any case, create a working plane and then change the text plane to Working Plane and it will be aligned to the working plane, but probably not in the location you want it to be. Quote Link to comment
grant_PD Posted May 4, 2020 Author Share Posted May 4, 2020 Hi Pat, I'm confused as how to go about this in Marionette. I just have some text I want to put on the front of an extruded object. Quote Link to comment
Pat Stanford Posted May 4, 2020 Share Posted May 4, 2020 I have no idea. I didn't realize this was posted in the Marionette forum. @sbarrett can you help? Quote Link to comment
m.graf Posted May 5, 2020 Share Posted May 5, 2020 (edited) something like that? Greatings M.Graf text to 3d-Objekt.vwx Edited May 5, 2020 by m.graf 1 Quote Link to comment
grant_PD Posted May 6, 2020 Author Share Posted May 6, 2020 Yes that's very cool. I was looking for a way to align text to an extrusion rather than a plane. But debugging your script let me look at the matrix in question, so I think I can futz with the numbers and come up with a solution. Thanks! It's these type of simple scripts that I wish were available for every node, so beginners like me can see what is supposed to happen w/ each node. Quote Link to comment
m.graf Posted May 6, 2020 Share Posted May 6, 2020 another solution: text "convert to poly" and rotate Text_to 3d-Poly.vwx 1 Quote Link to comment
