Mr_Brooks Posted May 2, 2020 Share Posted May 2, 2020 Hi all, Let's say we have 3 differents walls with different heights. I'd like to increase proportionaly its heights on Object Info cell "Height" Is there a command to do that? Something similar than C4D "num +100" Thanks Quote Link to comment
Hans-Olav Posted May 2, 2020 Share Posted May 2, 2020 Hi You can change the height by adding + 100 after the current height in the OIP, but if you choose several with different height they will all get the same height. Quote Link to comment
Mr_Brooks Posted May 2, 2020 Author Share Posted May 2, 2020 Thank you for reply, I'm looking for proportional behavior (something like "x +100" should add 100 units to each wall height even if walls have different heights) Quote Link to comment
Hans-Olav Posted May 2, 2020 Share Posted May 2, 2020 I don't think it's possible. It's only working for walls with the same height. Quote Link to comment
Boh Posted May 2, 2020 Share Posted May 2, 2020 If the bottom offsets are the same then you move them all vertical vertically 100 then readjust the bottom offsets back to what they were. You would have to readjust any doors or windows or symbols in the wells back down 100 tho. Quote Link to comment
