NickB Posted December 2, 2005 Share Posted December 2, 2005 Hi all, I've created a floor slab hybrid object, then cut a hole in it by editing the floor and drawing the polygon hole. If I change my mind though, how do I 'heal' the slab again? Editing the floor lets me move polygon vertices around, but it won't let me delete vertices to make the hole disappear. Any tips? Thanks, Nick Quote Link to comment
CipesDesign Posted December 3, 2005 Share Posted December 3, 2005 Hey Nick, If you double click the floor you will be able to edit the poly from which it was created (you know that part already!). All you have to do is draw a rectangle (or other poly) which completely covers the hole, then select the original poly, then the new one and use MODIFY>ADD SURFACE. HTH's :-) Quote Link to comment
NickB Posted December 3, 2005 Author Share Posted December 3, 2005 Thanks Peter, hadn't thought of that. Should've done, but just didn't. That helps a lot. Cheers, Nick. Quote Link to comment
