1. Can't number records formats that are not in the route directory. For example if i have created folders to tidy up the resource manager i then can't use spotlight numbering tool to number those items with record formats in a folder. If i move the record format to the root directory i can then use it in spotlight numbering. In the screen shot the only record format that appears in "plant Record". I have as you can see lots of record formats.
2. Numbering generation with spotlight numbering. It seems there is a small bug or i've missed something in the way you number if you use a complex numbering system, for example if i wanted to number 24 units S0001 to S0024 i would put the S in the Prefix box and then add 0001 to the start number. However VW strips out the 0's from the units numbered after the first unit. I found this out when using spotlight numbering to number other things that require complex numbering.
Mike Williams
Hi Found a few bugs in spotlight numbering.
0 answers to this question
