hklem Posted April 29, 2020 Share Posted April 29, 2020 Hello,  When I am using the push pull tool it seems it can only create a new object and not alter the object I am trying to alter. When I try to cut in a sketchy box shows up. Hoping this is an easy fix 😮 Quote Link to comment
zoomer Posted April 29, 2020 Share Posted April 29, 2020 Yes, the fix is your Timing when using the ALT key to subtract. Â Can't describe it exactly when. I try each time from scratch when I need it. But you could also just use standard Add/Subtract Solids. It is basically the same. Quote Link to comment
hklem Posted April 29, 2020 Author Share Posted April 29, 2020 @zoomer Unfortunately, that most like is not the fix. I was able to do it just fine yesterday and the day before but now I am running into this. I think it may have something to do with when I am in push pull it does not recognize an active layer. Thoughts? Thanks! Quote Link to comment
hklem Posted April 29, 2020 Author Share Posted April 29, 2020 Attached is a look at what I mean. Quote Link to comment
zoomer Posted April 29, 2020 Share Posted April 29, 2020 Would have been an easy answer 🙂   There were rare posts on this Forum about the ALT key being ignored for whatever reasons in the past. I assume you tried restarting VW and OS already.  For the Layer maybe like Boolean operations it needs to have all Objects on the same active Layer ? Quote Link to comment
markdd Posted April 30, 2020 Share Posted April 30, 2020 (edited) The third mode of the push/pull tool would seem like the option you need. Edited April 30, 2020 by markdd Quote Link to comment
