Jim Smith
The best / most easy 2nd party render software
For most of my work, I like Open GL with a Sketch filter as it communicates the design intent, while keeping things a bit rough so clients don't feel the design is "Finished".
That said, we are being asked for more "realistic" renders more and more. Camera Match has it's advantages and RW is fine for many of these clients but we are being shown examples that I don't think I can reproduce in RW.
I know that one of the best things about VW is there's more than one way to skin a cat, but I'm curious if there's one best 2nd party render software to take renders to the next level. I think that Cinema 4D was often seen as the default but is this still the case? I don't know what I don't know so this question may not have a clear answer, and from looking around the forum, I really don't get a clear direction.
What are others using to take renders to a more photo realistic level?
What are you NOT achieving using Renderworks? I also like C4D, but I firmly believe there's a lot you can achieve within the VWX ecosystem
29 minutes ago, TomWhiteLight said:
Hi Jim I can send you a file with some great renders. I will email you a link.
I’d like to see that file also!
RW is basically C4D.
You can get about 90% of C4D Quality in VW RW.
The rest is mostly just more comfort in organizing, setting up and rendering.
But if you have C4D you can add VRAY for C4D,
which will deliver the highest quality in (ArchViz) Rendering if you need.
Or Corona and what not ....
And very interesting are the current Real Time Renderers with decent quality
vs full CPU Rendering. Which you can use also directly from VW by Plugins.
Like Lumion, Enscape (Beta) and Twinmotion (Plugin soon ?)
@zoomer @Kevin Allen @TomWhiteLight I guess my RW skills need some work. I find it really hard work to light, find & edit textures. I've used the cloud rendering but the issue I find is the lag time between what I've done & what needs to be changed. As I say, I guess I need to work at RW more to improve my renders.
Try Enscape Beta.
It works pretty ok with VW RW setups and is basically a one button solution.
EDIT
Yes, beside Twinmotion, most Real Time solutions are Windows only.
I like Twinmotion very much though.
Could I take advantage of your offer as well?  I'm just learning some RW techniques and I'd like to see where the bar is set.  Thanks.
Get in touch with the US training team and I am sure a good online session would set you up. It's worth getting the custom render style right on your machine first then using the cloud to do the hard work.
10 hours ago, zoomer said:
Try Enscape Beta.
EDIT
I use two realtime programs on the Mac, Artlantis and Keyshot, both available for Mac and Windows. So, it's not all Windows.
I have to say that I much prefer realtime rendering. It's definitely the way to go in the future. You may not get to exactly the same the final rendering quality, but close enough, and you save a lot of time.
Posted (edited)
@Jim Smith  I think if you want real photorealistic you should factor in sending it out to a 3d vis company.  Renderworks is basic and more for outline communication / design intent with clients , while the 3d vis companies do the brochures / sales buff stuff , with the nice lens flare and depth of field etc!
The dedicated 3d render packages just have too many features missing from render works and ease of use.
Definitely move from OpenGL to renderworks though - there's loads of sites for textures (poliigon.com , textures.com), an OpenGL v renderworks image below (image took 1min.23 secs in renderworks)
Edited by fabrica
time of render
hmm not sure I agree...
With some time and training VW might be enough. Also take a look at the design summit recording to see how we are improving these workflows in the next version.
@TomWhiteLight you have to say that !   😀
but there's no way renderworks will ever have the ability or features of vray or corona etc , and all the associated plugins with those. (and nor should it as thats not its function)
I like renderworks btw but its not for the high end arch viz renders some clients want.
you just can't do in renderworks the examples from here:  https://corona-renderer.com/forum/index.php?board=3.0
Looks great but if you don't want to make the leap as you can see you can do alot with just Vectorworks.
Also
Lumion
NScape
Twinmotion
Unreal Engine
to name a few
Just now, TomWhiteLight said:
link above!
theres 5 keynote videos ? which one has the new renderworks features?
My 2c - if you're on Windows Lumion knocks it out of the park for ease & speed, and it comes with a huge collection of entourage and materials that's pre-optimized. (<- is that even a word?)
I just rendered these a minute ago to show you. They are from a couple of the built-in example files. Rendered 1080p in 40s 31s 30s (s=Seconds!!!) respectively and I kid you not!!
And animations, are on a par with this. Think rain, fog, puddles, ocean, car paths, walking figures, moving clouds, leaves water etc. .... it's mind boggling when you see it.
Posted (edited)
ps - I wouldn't want to be cleaning leaves from that pool
Edited by bcd
Lighting and texture creation will be key to whatever you do and wherever you render. If you have some familiarity with renderworks and clearly have the program, part there.
I might suggest rather than try to render an entire project, start with simple forms, build textures, render those, see what works, then you can also ask specific question her "How do I make the XX better?"
Same with lighting, the fewer the lights, the better for speed no matter the application. Frankly, a lot can be done with the proper lights properly placed. Avoid the point light.
Look at Renderworks Styles, with and without HDRI illumination, you do not need to start with high quality or FQR. go for speed, test and repeat.
I;'m a Mac user, so I can't speak to mum ion, but Twinmotion requires a lot of computing power. It deliver magnificent work.Moving back and forth between VWX and C4D can be a bit tedious in the early design stages, but you can also use C4D to create textures for VWX.
