Dean Posted December 2, 2005 Share Posted December 2, 2005 I've got a project that is spread over several documents that seem to have acquired several different dash styles. Is there a way I can import a standard list of dash styles across all the files or do I need to go into the Set Attribute Defaults and set each style by eyeball for each document? Quote Link to comment
Jonathan Pickup Posted December 2, 2005 Share Posted December 2, 2005 you may be able to do this with a DXF file. Test this on a copy of your files first! Create a file with a few lines that use the dash styles that you want. Export it as a DXF file. Import this file DXF into the document you want... A DXF file brings dash styles with it and can over-write existing dash sytles... Quote Link to comment
Dean Posted December 5, 2005 Author Share Posted December 5, 2005 Thanks Jonathan, I'll investigate that. That actually might be how I got into trouble in the first place, but it might get me out of it as well. Dean Quote Link to comment
