Tom M.
Weird Text Issue in Marionette Object Node
Hi there,
i have a strange issue in a marionette object node.
The network outside of an object node works perfect. But in the Object node the textfields changes randomly their position.
Does anyone know something about this problem or are some connections wrong inside of my network?
Posted (edited)
13 hours ago, Tom M. said:
Hi there,
you can try to add the <Point> node (with correct Coordinates) at all "Easy Text nodes"
than try the <dummy end> node, instead of <Pass> node at the end of your Marionette network
greatings M.Graf
Edited by M.Graf TH-OWL
Posted (edited)
I tried this before, same issue...
237271186_Bildschirmfoto2020-04-29um18_37_20.thumb.png.60b07fe89035bb7f2b2d25d1efdb3f5c.png224911287_Bildschirmfoto2020-04-29um18_37_14.thumb.png.3ac38140a73a852c12b1d4c9403094e9.pngRight now i have implemented the point coordinates direct in the "easy Text" node.
the dummy end node also brings no improvement.
Thanks for the hints M.Graf
Edited by Tom M.
Hi @Tom M.
Any chance you'd be willing to send me that file (or a simplified one) so I can take a look at your network?
You can send it to me in a direct message if you aren't comfortable sharing to this thread.
i found the issue 🙂
another "String Node" (tested with string "_",  and " ")
at the ItemFalse Input by every "If Node" and your Marionette Object works fine!
greatings M. Graf
1435859813_Bildschirmfoto2020-05-05um11_50_57.thumb.png.6cdd01ae7a76d23d0f5f2cf9d155fee7.png
957295322_Bildschirmfoto2020-05-05um11_51_12.thumb.png.5c6d4e41a563536071626da0096594c1.png
@Tom M.
found another bug:
if the String node "1_Raum_ID" or "2_Bez" is empty - same issue.
wrote a little Script in the String Node, it change "empty String" to "Space" / "Leerzeichen"
Weird Text Issue-bugfix.vwx
greatings M. Graf
@m.graf
thanks for the updated string node.
I tried this workaround with the Space as well 😉 because I discoverd that the positioning error only happens if one string is empty.
But I wanted to understand why this random positioning happens because all the text nodes have their specific insertion point.
For the moment I can work with this workaround. Thanks
I really appreciate your help.
Looks like that marionette sometimes does what it wants to do 😉
