Biscontin Posted April 28, 2020 Share Posted April 28, 2020 See video... Basically, when I snap a dimensions to a CENTER point... the dimension does not "follow" the object if I move it!!! Dimensions follow object ONLY if snapped to END/CORNER points. Why? Is there any options I should turno off or on? Screen Recording 2020-04-28 at 15.49.39.mov Quote Link to comment
0 Pat Stanford Posted April 28, 2020 Share Posted April 28, 2020 The center edge points set by the "Eight Selection Handles" preference are not really points on the object. They are only for visual reference. I know you can grab them and drag/stretch objects from them, but the Constraints that are used to make Associative Dimensions can't see them. Depending on what you object types are you might be able to modify your objects to create a Handle at that point (Replace a rectangle with a 5 point polygon with the beginning and end points at the center of an edge.) Or add a locus point and Group the object and locus to give you a Handle to associate the dimension with. Sorry. Quote Link to comment
0 Biscontin Posted June 5, 2020 Author Share Posted June 5, 2020 That's unfortunate 😓 Quote Link to comment
Biscontin
See video...
2 answers to this question
