bicameral2 Posted April 27, 2020 Share Posted April 27, 2020 I just saw MRoth's "forward" and "backward" nodes, which i think are very cool. I've often wondered why there isn't a "send" node. Does anyone know why? Have i just missed it? Is there a "send" work around? Quote Link to comment
Marionette Maven Marissa Farrell Posted April 27, 2020 Marionette Maven Share Posted April 27, 2020 So I think the primary reason is the command used in those nodes doesn't behave the same between networks and object nodes. One way to specify the drawing order would be to use an ordered list to determine which object is drawn first and so forth. Quote Link to comment
Antonio Landsberger Posted April 28, 2020 Share Posted April 28, 2020 If the ordered list is not enough you may need to put a group behind it for the objects to be drawn in the correct order. Quote Link to comment
