fjtb Posted April 26, 2020 Share Posted April 26, 2020 Hi Conrad, Can you explain how the "Room" function works? I suppose you can add devices to a room or venue automatically, but its not the case during my tests. I'm also not able to assign a device to a room manually in the object info pallet. Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted April 26, 2020 Vectorworks, Inc Employee Share Posted April 26, 2020 Rooms live on the layout layer. You need to do Update Rack Elevation to put whatever devices are on the current layer onto the layer Rack Elevation as Equipment Item objects. Then draw your Room there and maybe place a Rack too. Then you can assign Equipment Items to Rooms and Racks just by drag - dropping them in. When you go back to your schematic you'll see that the location data is entered in the devices and displayed just under the description text. Conrad Quote Link to comment
fjtb Posted April 26, 2020 Author Share Posted April 26, 2020 Oke that works... but: The device name or tag is connected to the room function. What means I need to add all my devices two times in my engineering. One time in the layout layer and one time in de schematic layer? Is that the case? Or is there a more efficient way to do this? Can I pull the devices from the schematic layer to the layout layer? I prefer to have my schematic leading. So it would helpfull if I can draw the room in my schematic, is that also an option? I'am now working on a project with more than 2500 items spreaded out over 63 venues , so some efficiency is helpfull 😉 Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted April 27, 2020 Vectorworks, Inc Employee Share Posted April 27, 2020 Hi Frans Thanks for your forthright comments. Right now it works the way I told you. The Update Rack Elevation command does most of the work for you - all you have to do is drag and drop your equipment into racks and rooms. Most people find that quite efficient. Obviously I'll keep your workflow in mind but any change would be for a future version. Thanks! Conrad Quote Link to comment
Noah C. Posted May 11, 2020 Share Posted May 11, 2020 Hey Conrad, I am having trouble with the "Update Rack Elevation" command. No objects are populating on the 'rack elevation' layer from my schematic layer. All schematic devices are physical, not virtual. Working from the ConnectCAD template file. Anything that I might be missing? Thanks, Quote Link to comment
fjtb Posted May 12, 2020 Author Share Posted May 12, 2020 Should that go automatically 😳 Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted May 12, 2020 Vectorworks, Inc Employee Share Posted May 12, 2020 Hey Noah The only way I can see is if you send me the file - either post it here or send me via PM if you are more comfortable with that. Conrad 1 Quote Link to comment
Noah C. Posted May 12, 2020 Share Posted May 12, 2020 (edited) Attached. Thanks so much for the help Conrad. ConnectCAD Test.vwx Edited May 12, 2020 by Noah C. Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted May 12, 2020 Vectorworks, Inc Employee Share Posted May 12, 2020 Works for me. Using Update Rack Elevation.pdf Quote Link to comment
Noah C. Posted May 12, 2020 Share Posted May 12, 2020 Hmmm, that's no good. Any further suggestions to try here? Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted May 13, 2020 Vectorworks, Inc Employee Share Posted May 13, 2020 Not really. I created that how-to using the file you just sent me. Everything worked as expected. I think you need to call Support go through it with them, and either they'll help you fix it or they'll file a bug and we will fix that. Sorry, but if I can't reproduce the problem using the same file that you say doesn't work, I've run out of options. Conrad Quote Link to comment
Noah C. Posted May 13, 2020 Share Posted May 13, 2020 Sounds good. I'll give that a try. Thanks for the help Conrad. Quote Link to comment
Noah C. Posted May 13, 2020 Share Posted May 13, 2020 Hey Conrad, I worked with tech support on this and actually sorted out what my issue was based on your video you sent. I was using the "update rack elevation" command while I was in the 'Rack Elevation' layer. When I apply the command from the 'Schematic" layer, it works like a charm. I just wanted to let you know in case you run into something like that in the future. As a new CC user, I hope that as VWX continues to develop and improve ConnectCAD that the documentation and training materials for it improve along with it. Thanks again for the help. I am sure I'll have further questions to bother you with as I integrate CC into our company template file and project workflow. Cheers, 2 Quote Link to comment
