P Bartoli Posted November 28, 2005 Share Posted November 28, 2005 Sometimes it happens that dimensions readout is too accurate and you'd like the dimension to be indicated as something else. I try to explain: I'd like to break the dimension to change the value to what I'd like it to be. What tool should I use? thanks! Quote Link to comment
P Bartoli Posted November 28, 2005 Author Share Posted November 28, 2005 Convert to group is the right answer? Quote Link to comment
David Ormsby Posted November 28, 2005 Share Posted November 28, 2005 In the object info window you can turn the fractions on or off, and you can also manually enter the length of the dim. Quote Link to comment
Travis Posted November 28, 2005 Share Posted November 28, 2005 You can also "uncheck" the Show Dim box. Then you can enter whatever dimension you like. Quote Link to comment
matto Posted November 28, 2005 Share Posted November 28, 2005 Also you can modify the rounding base in "Units" so you only get multiples of 5. Convert to group should be the last option. Quote Link to comment
