Kevin C Posted April 23, 2020 Share Posted April 23, 2020 As we all know, getting Vectorworks to draw a roof properly is near on impossible and we usually all spend hours if not days getting one correct - even although there usually has to be a few 'workarounds' to get them to display properly. Question is - Is there a way of bringing the settings from one project into another. It might sound easy, but for some reason, things like pitch / overhangs / inert /eaves profiles and all the other things which take for ever to set up are never copied over. The eyedropper does not go into that much detail. Any help would be appreciated. Quote Link to comment
zeno Posted April 24, 2020 Share Posted April 24, 2020 (edited) Hi It depends on what you want to transfer from one project to another. 🤔 If you need transfer wall styles and connection components with a wall, of course you have to transfer both styles. Often you have to define a set of slab wall and roof Componenti 2 v2020.vwx Edited April 24, 2020 by Zeno Quote Link to comment
