MYHABITATDESIGN Posted April 23, 2020 Share Posted April 23, 2020 Hello - i found some old posts on this however not really what i am looking/hoping for.... Is there a way to create a skirting without building into the wall style? for example just dragging along the walls to place there in front? wishful thinking i hope!! thank you Quote Link to comment
bcd Posted April 23, 2020 Share Posted April 23, 2020 The simplest way, if your walls are closed is to use to Polygon too - inner boundary (bucket fill) mode to create a Polygon on the floor Use this as the path for an EAP. Edit the EAP and move the corner of the profile to 0,0 Easy miters and you can either split the Path or Subtract Solids at doorways Quote Link to comment
ThreeDot Posted April 23, 2020 Share Posted April 23, 2020 Take a look at Andrea Facchinello's fantastic Baseboard plug-in. https://plugins.andreafacchinello.it 1 Quote Link to comment
