blimey Posted November 19, 2005 Share Posted November 19, 2005 In VW11.5 I could workgroup reference a file and check no layers. It would then reference all the symbols. Doesn't this work anymore with VW12? I've tried but the symbol are not in Italics and do not update. I've tried to reference the file both from the workgroup reference dialog box or from the resource browser. It does reference my file without any layer, but I cannot acces the symbols??? The only way I have found is to create a layer call LIBwindows for windows library for ex and to put an instance of the symbol there and then to reference that layer of the file??? Is this normal? Quote Link to comment
Guest Posted November 25, 2005 Share Posted November 25, 2005 Simply right click on the symbols you want to reference and select reference. With VW 12, you no longer have to refernece a file to reference only resources in that file. All you have to do is have the file either open under "Open Files" in the Resource Browser or saved as a Favorite in the Favorites list. Quote Link to comment
blimey Posted November 28, 2005 Author Share Posted November 28, 2005 Hi Bruce, Thank you for checking this for me. I've tried your way. It works. Best Li Mei Quote Link to comment
Vectorworks, Inc Employee Bruce Ferguson Posted November 29, 2005 Vectorworks, Inc Employee Share Posted November 29, 2005 LiMei, Thank you very much for your assistance with this problem. When I tried to duplicate what you reported, I had my source file on the local harddrive. When I moved it to a network drive, I saw the problem you reported. With further checking, I found that this is only a problem on Windows. Also I believe it is only a problem if you have mapped network drives. For instance, I have an Engineers volume that I have mapped to be drive E: on my Windows machine. When opening a source file from the Engineers volume on the resource browser (either doing a Browse or an Add to Favorites), if I navigate to it by clicking on the E: drive under My Computer, I have the problem. However if I navigate to it by going through My Network Places, then I don't have the problem. So you can work around the problem by not using network volume mappings for now. This will be fixed for a future version of VW. -------------------- Bruce Ferguson bruce@nemetschek.net Quote Link to comment
