markdd Posted April 16, 2020 Share Posted April 16, 2020 Currently, weight values for Lighting devices are reported to worksheets using the measurement and the Unit (ie 42 kg). This means that the SUM function will not work. Is there a way of stripping out the "kg" or "lbs" value to just see the number, or is there a function that I should be using that ignores the Unit suffix? Any help would be really helpful. Many thanks Mark Quote Link to comment
Pat Stanford Posted April 16, 2020 Share Posted April 16, 2020 You will probably need to use a double function something like: =Value(SubString('Lighting Device.Weight',' ' ', 1)) SubString use these the second parameter (in my example two single quotes with a single space between them) is the delimiter. Every time there is the delimiter character in the string Substring will recognize that as a separate part. The last parameter (One (1) in my example) is which of those parts to return. So the substring above will return the part of the weight field before the first space. [I know that the record/field is probably wrong. I would have to switch workspaces to try and find the correct names.] The Value converts the text returned by the substring into a number that you can do math on. 2 Quote Link to comment
markdd Posted April 16, 2020 Author Share Posted April 16, 2020 This is great Pat. Slight correction to your function: =VALUE(SUBSTRING('Lighting Device'.'Weight', ' ', 1)) Works like a charm Many thanks Mark Quote Link to comment
Pat Stanford Posted April 16, 2020 Share Posted April 16, 2020 I thought I probably had the quotes wrong, but figured you are good enough to get it. Glad to help. Quote Link to comment
markdd Posted April 16, 2020 Author Share Posted April 16, 2020 I would like to combine the weight values of 2 database headers to give the combined total of Lighting Pipe and Lighting Instrument. I have a feeling I need the CONCAT function, but cannot workout how to combine it with the VALUE function. Can this be done? Thanks Quote Link to comment
Pat Stanford Posted April 16, 2020 Share Posted April 16, 2020 I don't think Concat is what you want. All that does is combine strings. I think you need IF instead. Set up a database that contains both Lighting Pipes and Lighting Instruments. Use something like this: =IF('Lighting Pipe'.'Weight <> '', Value(Substring('Lighting Pipe'.'Weight', ' ', 1)), Value(Substring('Lighting Instrument'.'Weight', ' ', 1))) The above says that if the weight field of the lighting pipe is not blank then use the value of the lighting pipe.weight record otherwise use the value of the Lighting Instrument.weight record. Quote Link to comment
markdd Posted April 16, 2020 Author Share Posted April 16, 2020 Hi I can't seem to make it work. I just want to combine the weights into one column so that I can get the totat weight of a lighting pipe with it's associated Lighting Devices. Here is what I have so far just to give you context. (i've attached the file as well Thanks Pat Mark Weight Field.vwx Quote Link to comment
Pat Stanford Posted April 16, 2020 Share Posted April 16, 2020 Put this formula into cell E2 =IF('Lighting Device'.'Weight'<>'', C2, D2) Once you get that working (tested here), you can replace C2 and D2 with the actual formulas from those cells so you don't need the extra columns. Quote Link to comment
markdd Posted April 16, 2020 Author Share Posted April 16, 2020 Thanks Pat I think this will work. I'm going to work on this some more tomorrow.... Just out to get my daily 10,000 steps during lock-down! Quote Link to comment
Alexey Trebukhin Posted October 14, 2020 Share Posted October 14, 2020 @markdd Hi! How did you manage this formula: "=VALUE(SUBSTRING('Lighting Device'.'Weight', ' ', 1))" to work? I'm struggling with text to numbers issue for "Wattage" and "weights" field since 2019! 🙂 And it seems for me that you found the solution? What am I missing? Thank you in advance! Quote Link to comment
markdd Posted October 14, 2020 Author Share Posted October 14, 2020 You are counting symbols and not lighting devices. Change the B column to Lighting Device Instrument Types and then the string in Column D will have the correct item to look at. Quote Link to comment
Alexey Trebukhin Posted October 14, 2020 Share Posted October 14, 2020 @markdd still doesn't work for me 😞 Should I try anything else? Quote Link to comment
markdd Posted October 14, 2020 Author Share Posted October 14, 2020 Take a look at this worksheet Worksheet.vwx Quote Link to comment
Alexey Trebukhin Posted October 14, 2020 Share Posted October 14, 2020 @markdd Thank you! It works perfect! And I found my mistake! 🙂 Quote Link to comment
