Charlie M Posted November 18, 2005 Share Posted November 18, 2005 I posted this in the Architect forum, but maybe it will get a bit more exposure here. I just created a titleblock and linked all my text to the correct record, and added some extra fields. Those fields won't show up in the Issue Manager, so I assume the record fields aren't linked to the issue manager so you can't add or delete fields. Is there a way to add fields and they can be used through the issue manager? Thanks. Quote Link to comment
blimey Posted November 21, 2005 Share Posted November 21, 2005 Hi Charlie, i created a titleblock and it worked fine. at first the fields didn't show up in the Issue Manager as I didn't put the prefix P_ for project field and S_for sheet field (it's in the manual). Once you do that it works fine. you have to reset completely the files thought (only new files will work). good luck Quote Link to comment
