AlHanson Posted April 15, 2020 Share Posted April 15, 2020 I've been using the Ordered List along with the Concatenate Node to combine strings for my tools for a while now and have never had any issue with it. Recently, I've been having trouble getting this to function correctly as it has started giving me a list style string. In this example I'm just trying to create a simple #/# value display- just a simple / between two string values. I should be getting 1/23 from this however I'm getting ['1', '/', '23']. I've generally been working with the ComputerWorks Easy Text node, so I checked this against the stock Text node and the problem exists here too. The weird thing is that if I go back to my tools that have used this exact same method to generate text and copy/paste the Ordered List & Concat nodes into the file they work just fine and produce the previously expected results. Checking the script in the newly inserted nodes versus the copied node shows no difference- they match up exactly. Example file attached. Very confused with this and looking for some help or guidance on a better method for building strings? TextConcat.vwx Quote Link to comment
DomC Posted May 6, 2022 Share Posted May 6, 2022 As the concat node is, it converts the input to a string and then loop the character and adds them. #inputs stringIn = str(self.Params.stringIn.value) #script newString = '' for s in stringIn: newString = newString + s #outputs self.Params.stringOut.value = newString I am not sure but I would expect from this node, it should do something like this: #inputs stringIn = self.Params.stringIn.value #script newString = '' for s in stringIn: newString = newString + str(s) #outputs self.Params.stringOut.value = newString Quote Link to comment
