Charlie Winter Posted April 14, 2020 Share Posted April 14, 2020 I seem to recall a script floating around for quickly changing DPI on sheet layers.. am I crazy? I'm working on testing render styles on viewports in a sheet layer and would like to quickly switch between a low and high resolution DPI. Is this possible via a Vectorscript? Quote Link to comment
Julian Carr Posted April 14, 2020 Share Posted April 14, 2020 I don't recall a script, but you can just select all the sheets in the Nav palette, right click, choose Edit, then change the DPI there. Only takes a few seconds. Quote Link to comment
