The Anorak Posted April 14, 2020 Share Posted April 14, 2020 Hi All, Not sure if anyone else had had this problem, but I have a model file with stories and wall tags, floor types etc embedded in it. Whenever I update this model file which is referenced into a plot file the stories disassociate from each layer. This causes my stair cases to just appear as red error text. I then manually re-attach the stories to their correct layer (this fixes the stairs). After doing this a number of (not all) my data tags revert back to some default value which I don't even recall setting. Any thoughts on how to resolve this? Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted April 14, 2020 Vectorworks, Inc Employee Share Posted April 14, 2020 Please can you contact UK Technical support and send them the files to look at? uktech@vectorworks.net The story set up needs to be identical in all reference files. Could it be that the stories are not set up the same way in all the files? The story system itself cannot be referenced. Quote Link to comment
