moti Posted April 11, 2020 Share Posted April 11, 2020 I would like to place 100 fixture equally in the spiral I created. What's the way? Quote Link to comment
markdd Posted April 11, 2020 Share Posted April 11, 2020 Is it a 2d or 3D spiral? Quote Link to comment
moti Posted April 11, 2020 Author Share Posted April 11, 2020 It is 2d , i need to locate the fixture on floor. Thank you Quote Link to comment
markdd Posted April 11, 2020 Share Posted April 11, 2020 Use the duplicate along path command from the Edit menu. If you are using a spiral made from the spiral tool then you will need to ungroup it. select spiral and lighting device and run the command. 1 Quote Link to comment
