Go For Mike Posted April 7, 2020 Share Posted April 7, 2020 Hi, how is it possible in a viewport to show only the data visualisation objects in colour and all other objects/layers in black and white? - without this affecting viewports which require all colours visible. Thanks Quote Link to comment
Pat Stanford Posted April 7, 2020 Share Posted April 7, 2020 Use Class Overrides to set everything to Black and White and then use Visualization to set the colors back? You can select all the classes at the same time and set the overdose for them all at once. Quote Link to comment
Go For Mike Posted April 7, 2020 Author Share Posted April 7, 2020 The override work for all but one symbol and one group in the drawing. At first I thought it was that the object themselves were not coloured by class in attributes however that hasn't fixed it. Any ideas? Quote Link to comment
Go For Mike Posted April 7, 2020 Author Share Posted April 7, 2020 Scratch that it was in the original attributes. Thank you both very much for your help. Mike Quote Link to comment
Pat Stanford Posted April 7, 2020 Share Posted April 7, 2020 Symbols and Groups are container objects. If you hide/set to invisible the class of either the container or the contained objects they will not be visible. But objects inside the container can have their own classes and attributes, so you need to make sure that what is inside the group/symbol is also set to use Class Attributes. Glad you sorted it. Quote Link to comment
