blimey
A bug in VW12's Standard Naming
I've set up all the classes, layers, viewports in the worksheets (ClassNameStds,LayerNameStds, ViewNameStds). I DIDN'T TOUCH at the LayerMapG.
Then I ran the set up : model set up; create stds VP; Then I ran the standard Naming... It computed and made the correspondances. EXEPT for the Mod-Framing roof Layer.
I did it 4 time, double checked that the name was good in the standard naming command (in details). it was correct but would generate. I changed manually the name of the layer into my stds. Than I ran it backward. It correctly translated the name back in Mod-Framing-roof layer. I did it again in my direction... woops didn't work.
I thought that may be I asked too much generating all the possible plans. So I started a brand new file and created ONLY the Roof frame plan and the Roof plan. Reaction was exactly the same.
I saved the file for info. Would anyone care about having a look?
