frv Posted April 6, 2020 Share Posted April 6, 2020 Hi, In a new file I can change the text size of a drawing label but in a working file with labels already present I can no longer change the text size for drawing labels. Although I can push all the right buttons the text size won't change anymore. So going to do some viewports at a larger scale the drawing labels are miniture labels without any change of enlarging them. The max. text size of 36 is a in some cases also a bit small especialle when I am making a few 1:1 details. Any idea what is happening ? Quote Link to comment
frv Posted April 6, 2020 Author Share Posted April 6, 2020 (edited) Found the problem. The label takes the textsize defined in the class regardless the settings in the labels Object Info. My labels ended up in de class dimension.. A bit confusing at times when the class setting is dominant over de object info plugin settings. They should be grayed out in case they are overruled. Edited April 6, 2020 by frv Quote Link to comment
