frv
drawing label change text size problem
Hi, In a new file I can change the text size of a drawing label but in a working file with labels already present I can no longer change the text size for drawing labels. Although I can push all the right buttons the text size won't change anymore. So going to do some viewports at a larger scale the drawing labels are miniture labels without any change of enlarging them. The max. text size of 36 is a in some cases also a bit small especialle when I am making a few 1:1 details.
Any idea what is happening ?
Posted (edited)
Found the problem. The label takes the textsize defined in the class regardless the settings in the labels Object Info. My labels ended up in de class dimension..
A bit confusing at times when the class setting is dominant over de object info plugin settings. They should be grayed out in case they are overruled.
Edited by frv
