Cammy 0 Posted April 5, 2020 Hi How do I create an object in Vectorworks from this image that I can import to other 3d model files. Ive tried just importing the image to the Vectorworks file of the theatre but when I export the Vectorworks file the images don't appear. Quote Share this post Link to post
Andy Broomell 1,025 Posted April 5, 2020 What filetype are you trying to export to? Quote Share this post Link to post
JBenghiat 333 Posted April 6, 2020 Your easiest option is going to use the Model menu to create an Image Prop. If the transparent area is an alpha channel, your will get the image in your model rather quickly. When you export, it will be a polygon with a texture applied. I'm not sure you the import process will deal with the transparent section correctly. If you need to create the geometry, I would use Illustrator to find the path and then export/import as dxf. You can then manually apply the texture. If you convert the image prop to group, you should be able to manually copy over the scale to get the texture to map properly. Quote Share this post Link to post
Claes Lundstrom 67 Posted April 6, 2020 Easy. Here is an example as VW, exported as OBJ, 3DS, and Collada. Set.zip Quote Share this post Link to post
Cammy 0 Posted April 6, 2020 16 hours ago, JBenghiat said: Your easiest option is going to use the Model menu to create an Image Prop. If the transparent area is an alpha channel, your will get the image in your model rather quickly. I can see Image Prop in the Model menu but its not highlighted so I can't select it Quote Share this post Link to post
JBenghiat 333 Posted April 6, 2020 32 minutes ago, Cammy said: I can see Image Prop in the Model menu but its not highlighted so I can't select it It should always be active, I believe even in Fundamentals. You just need to have a file open. Quote Share this post Link to post
