Benson Shaw Posted April 3, 2020 Share Posted April 3, 2020 (edited) Work flow options? An imported topo with property line converts well as dwg basic objects to vwx But a vwx property line object traced over the imported line segments produces bearings that do not match the survey bearings (text blocks). Others will work in vwx to generate a landscape plan. Rotational difference is ≈17°. So, I could: Hide the vwx bearings? and paste in the imported text? Rotate the vwx object so that the bearings report same as import? And, therefore rotate all the other imported data and vwx drawing objects over it. Adjust the vwx internal "North"? but how do I do that? Create/rotate a DVLP of the import? or of the vwx file with all the LA and Arch stuff? Any experience or conjecture welcomed. -B Edited April 3, 2020 by Benson Shaw data set Quote Link to comment
Vectorworks, Inc Employee bgoff Posted April 4, 2020 Vectorworks, Inc Employee Share Posted April 4, 2020 Is the file Geo Ref? The Vectorworks file? Quote Link to comment
Benson Shaw Posted April 4, 2020 Author Share Posted April 4, 2020 (edited) No geo ref. Also, I can use the rotation field in the prop line OIP, but then need to reorient. or rotate the source poly with the rotate tool from a known point, form the PropLine, rotate it back. OR? Edited April 4, 2020 by Benson Shaw OIP Quote Link to comment
