Kevin C Posted April 3, 2020 Share Posted April 3, 2020 Looking for some help please. My practice is probably is the same situation as most others at the moment. We had to scrabble around to get everyone set up for working from home with regards to hardware and basic software issues. The lockdown looks as if it is going to be going on for at least a few weeks, if not months (please no), and the 'haphazzard' office setup really has to be sorted out as things are starting to get messy (file structure, multiple copies of files etc.). There are a couple of things which we will not be doing - most notably is project sharing. This is of little or no use to a small practice (there are four of us) and we collaborate just fine with external consultants just fine - they all use AutoCAD or Revit, and does not get over the bigger problems of office libraries and standards, which are continually reset every time there is an update to VW. What we need is the following: A setup that allows each user to have their user preferences set. A set of office templates and libraries that is fully accessible by each member of the team (Title blocks as well) An ability to remove the libraries from the local machines and force everyone to use the office standards. This has been a goal in the practice for a number of years and have never managed to get it to work as we could just shout across the office when a change happened - this is much more important now than ever before as we can no longer do this. I can recall when I was using AutoCAD many years ago (around AutoCAD V12), that it was a simple task to change the preferences folder so that it would only read network files for certain items. We all have access to OneDrive for Business, so the network folders can be cloned to local folders and everyone should theoretically be able to work100% remotely and when we get back to the office - it would be a simple change to go back to reading from the network. What would be nice moving forward is when service packs and new releases come out that an option to simply download a custom setup along the lines: Download all the templates and libraries separately and give the option of saving them to a separate location (instead of the hard drive) Download and install the program as a standalone (with the current user data migration kept). We should be able to direct the installation to a network (or cloud sharing / local) folder so that the templates and libraries will be the same on each computer in the office. Any assistance would be greatly appreciated. Quote Link to comment
Christiaan Posted April 3, 2020 Share Posted April 3, 2020 1 hour ago, Kevin C said: A setup that allows each user to have their user preferences set. A set of office templates and libraries that is fully accessible by each member of the team (Title blocks as well) An ability to remove the libraries from the local machines and force everyone to use the office standards. If you're all on Macs then Apple Remote Desktop might be the most straightforward way to deal with 1 and 3. And a Workgroup folder on OneDrive for 2. Quote Link to comment
fabrica Posted April 3, 2020 Share Posted April 3, 2020 1 & 2 straightforward - put your drawings standards on your preferred cloud based system, not sure 3 is possible. someone needs to be in charge of 2 so libraries can be updated for all. Quote Link to comment
Kevin C Posted April 3, 2020 Author Share Posted April 3, 2020 We're on a combination of Mac and PC. Thanks Christian, but I don't think you understood the call for help. Apple Remote Desktop is useless. This is going on the assumption that we have been able to set this up previously. I have asked many, many, many people about this before and unfortunately everyone comes up with 'Workgroup folders'. Funnily enough I have never had a workgroup folder appear on the resource manager, no matter how many different ways it has been set up, that's where the problem lies. Quote Link to comment
Christiaan Posted April 3, 2020 Share Posted April 3, 2020 (edited) 7 minutes ago, fabrica said: 1 & 2 straightforward - put your drawings standards on your preferred cloud based system My experience of doing item 1 on Dropbox was not good. The problem is the log file is continually updating and so everybody's log file changes clog up the syncing queue. Edited April 3, 2020 by Christiaan Quote Link to comment
Kevin C Posted April 3, 2020 Author Share Posted April 3, 2020 Fabrica, Tried this - doesn't seem to work. Rebooted the machines and VW just doesn't want to find the folders. There will be a silly setting somewhere that directs everything to a local folder irrespective of user folders. Quote Link to comment
fabrica Posted April 3, 2020 Share Posted April 3, 2020 @Christiaan it should read as 2 on cloud and 1 on local computer Quote Link to comment
Kevin C Posted April 3, 2020 Author Share Posted April 3, 2020 Christiaan, Not using dropbox - know about that problem, that's why we are using OneDrive (also helps that as a business user I get 1TB of online storage) and I can choose when to sync from local to Network Quote Link to comment
Christiaan Posted April 3, 2020 Share Posted April 3, 2020 5 minutes ago, Kevin C said: Apple Remote Desktop is useless. This is going on the assumption that we have been able to set this up previously. I have asked many, many, many people about this before and unfortunately everyone comes up with 'Workgroup folders'. Funnily enough I have never had a workgroup folder appear on the resource manager, no matter how many different ways it has been set up, that's where the problem lies. The only way I know of to do item 1 is to manipulate each users preferences folder, and the only efficient way I know of doing that remotely is Apple Remote Desktop. I haven't used OneDrive, so maybe that could work. You don't need Apple Remote Desktop to use a workgroup folder on OneDrive (item 2). You just need OneDrive. Quote Link to comment
Kevin C Posted April 3, 2020 Author Share Posted April 3, 2020 Going to try again, but I'm not holding out much hope. Thanks for your thoughts. Quote Link to comment
Christiaan Posted April 3, 2020 Share Posted April 3, 2020 4 minutes ago, Kevin C said: I can choose when to sync from local to Network That would necessarily require extremely good communication, to know when others are working on files. We find Dropbox + Project Sharing works very well. Communication is only needed when working on large files together. Quote Link to comment
Kevin C Posted April 3, 2020 Author Share Posted April 3, 2020 Just now, Christiaan said: That would necessarily require extremely good communication, to know when others are working on files. Not really - Just set up the syncing to happen in the middle of the night. OneDrive has a set of conflict rules, so any sync conflicts are highlighted and are manually resolved. Shouldn't happen that often as this is for libraries and templates and if it does - I am judge, jury and executioner. Quote Link to comment
line-weight Posted April 3, 2020 Share Posted April 3, 2020 2 minutes ago, Christiaan said: That would necessarily require extremely good communication, to know when others are working on files. Having a whatsapp group for this purpose seems to work quite well! Quote Link to comment
fabrica Posted April 3, 2020 Share Posted April 3, 2020 @Kevin C it should appear on your resources as below - just make sure all icons ticked on top bar at red line? - you will have to set up the files first also. My understanding is that 1 is for each user and is not shared online - ie. each user can set up their own preferences and hot keys etc to suit. , 2 - templates, title sheets, wall styles etc are in a shared 'office' vectorworks file on your cloud. Quote Link to comment
Christiaan Posted April 3, 2020 Share Posted April 3, 2020 2 minutes ago, Kevin C said: Not really - Just set up the syncing to happen in the middle of the night. OneDrive has a set of conflict rules, so any sync conflicts are highlighted and are manually resolved. Shouldn't happen that often as this is for libraries and templates and if it does - I am judge, jury and executioner. We couldn't work like that as we can often have multiple people working on a file. We let Project Sharing be the judge jury and executioner. Microsoft Office apps also play nicely with Dropbox, so you can see if somebody is viewing or editing a file. Quote Link to comment
Boh Posted April 3, 2020 Share Posted April 3, 2020 This is an interesting read. If the lock down continues here in New Zealand for too long we will need to look at setting up file sharing on Dropbox or similar. At the moment however what we are doing is working really well. We have left our office workstations running and are simply remoting into our office network. No significant change in workflow, all libraries and resources all fully accessible like they were before. We use ms teams for keeping in touch which is simple, allows video conferencing and screen sharing etc. Hopefully it doesn’t get to the point where we have to abandon the office altogether. Quote Link to comment
Christiaan Posted April 3, 2020 Share Posted April 3, 2020 18 minutes ago, Boh said: Hopefully it doesn’t get to the point where we have to abandon the office altogether. We're thinking we'll do just that. Quote Link to comment
Popular Post techdef Posted February 17 Popular Post Share Posted February 17 One thing we've learned over the past 3 years now: we abandoned our file server and went 100% dropbox (in office and at home). No local storage, and no server. They key to getting everything working right with Workgroups and settings was to set the dropbox folder in a common location, ie: not a directory with the user's name in it! Mac (sorry, I dont use windows) defaults to putting the dropbox in the User/Your Name folder, which means all Xrefs and workgroup are broken. If you put the Dropbox master folder in /Users/Shared everyone sees the same folder hierarchy and the workgroups are perfecto. PS: lock your screen when you leave the office and the dropbox keeps syncing. Files are fresh when you get home. 5 Quote Link to comment
