frv 12 Posted April 2, 2020 Hi, maybe a question for a VW staff expert: Here at our office we have for years now forbidden to use the tool "rotate plan" in 2D drawings on design layers. In the past we noticed you can have serious problems with precision and dimensions in your drawings. Things seems to change after a rotate plan and turning back to zero again. Is this still a problem or has it been addressed or has it never been reported by others ? In other words, does a rotate plan changes the coordinates of objects in a file, even ever so slightly ? Quote Share this post Link to post
frv 12 Posted April 6, 2020 Did not see a response yet. Anyhow, I did a rotate plan in a rather large file and after it could no longer use the eyedropper tool. Had ro copy paste everything in a new file. Does anyone else has these kind of experriences ? Quote Share this post Link to post
unearthed 29 Posted April 6, 2020 How big is "rather large"? Is this megabytes or spatial extent? Quote Share this post Link to post
frv 12 Posted April 9, 2020 It was a file of 1.2 GB. But now in a 20 Mb file I also experience small but annoying off sets in the precision of geometry. 71 mm become 71.4 mm. After a few plan rotations...in a 12 Mb file. Quote Share this post Link to post
unearthed 29 Posted April 9, 2020 I can't help you. I have noticed some inaccuracy issues over the years with vw but I don't work to sub mm precision. Hope someone else can help. Quote Share this post Link to post
LarryO 18 Posted April 9, 2020 It sounds like your angle precision is set less than your orthographic grid's precision. Your precision for ortho would be minimum of one decimal place more than the smallest dimension you measure to maintain accuracy. Then your angle accuracy needs to be better than that and that accuracy is also relative to the distance from the rotation point to which you expect accuracy. If you are rotating your environment to angles other than whole degrees and you do this at 5 metres from the origin but expect accuracy to 0.1mm at 100 metres you have lost 5%(or maybe it's 20%) of your accuracy by doing the rotation at only 5M, unless your are entering the rotation value from the keyboard. Quote Share this post Link to post
frv 12 Posted April 15, 2020 Tx Larry. I changed my settings. As I understand now rotating plans can greatly effect precision. As I experienced in the past a well. Imagine plans are rotated along tilded axis all the time during a worksession files get completely messed up. I always thought it was just a screen/pixel related rotation. Quote Share this post Link to post
