AmperageProd Posted April 1, 2020 Share Posted April 1, 2020 Hope everyone is staying safe right now! I am trying to design a festival stage with a "diamond" video wall. Essentially using the LED tool to create a 6x6 wall at a 45 deg tilt so instead of sitting bottom to the stage, it would sit so the bottom left corner was directly down. There does not seem to be a way to rotate the wall around the Z axis, anybody have any suggestions? Quote Link to comment
C. Andrew Dunning Posted April 1, 2020 Share Posted April 1, 2020 At-present, the only way to do this without converting the LED object to a Group is to use a rotated Design Layer Viewport. Quote Link to comment
AmperageProd Posted April 1, 2020 Author Share Posted April 1, 2020 2 hours ago, C. Andrew Dunning said: At-present, the only way to do this without converting the LED object to a Group is to use a rotated Design Layer Viewport. Even making it into a group how can I rotate that? There are no options in the object info and using the right click->rotate function only works in plan mode Quote Link to comment
C. Andrew Dunning Posted April 1, 2020 Share Posted April 1, 2020 The "Convert to Group" Command (Ctrl-K) is different from Grouping objects. That command "disconnects" the object geometry from the code that created it. If you evoke that command while in a 3D view, you'll end up with rotatable 3D geometry. That caveat is that you'll also be eliminating all of the Plug-In Object functionality. Make sense?? 2 Quote Link to comment
