convert lines to polygons
Erin
3 answers to this question
Select the polygon.
Select the offset tool.  (basic tool palette, usually the 4th from the last tool.  It's a dim rounded corner, a bright rounded corner and an arrow)
Click on the tool preferences in the mode bar.  Looks like a pencil and wrench.
Select Offset by Distance
3'
Offset Orignal Object
Offset from Nearest Edge
Close Open Curves
Click one one side of the line or polygon and it will create a polygon, 3' wide.
Post back if that doesn't do what you need.
  • Like 4
