MichaelG Posted April 1, 2020 Share Posted April 1, 2020 Hi all, I need to create a surface and give it volume to try do some earthworks calculations. I have imported the data in a series of 3d polygons into VW and have tried to convert to NURBS curves and a few other things but keep getting errors when it comes to creating the actual surface. I typically used VW for structural drafting and a some 3d modelling so I'm a bit out my depth. Any help would be greatly appreciated Tin extraction.vwx Quote Link to comment
Benson Shaw Posted April 1, 2020 Share Posted April 1, 2020 If your license is Landmark, Architect or Designer you can use the 3d polys to creat a site model. Command is in the AEC >Terrain menu or Landmark>Create Site Model menu depending on which vwx ou have. post back if not working -B 1 Quote Link to comment
Benson Shaw Posted April 1, 2020 Share Posted April 1, 2020 FYI, the file is not downloading. Might be too big for this forum. Put in DropBox? -B Quote Link to comment
MichaelG Posted April 1, 2020 Author Share Posted April 1, 2020 Thanks Benson, Problem solved. 1 Quote Link to comment
